I use a transparant png logo on my invoice.
The backgroundcolor behind the logo is a color, but larger then the logo.
When printing the invoice the background of the transparant logo is a different color.
Kind regards, Koen
Kind regards, Koen
Have you considered removing the transparency from the image?
Hi Hillel,
It’s already a transparant logo.
The same occures on the Invoice Ninja Logo…
You don’t see anything on the pdf, but only when printing…
Greetings, Koen
Not sure I understand, I’m suggesting using a logo without a transparent background.
Hi Hillel,
No, it’s a logo with transparant background, its also happens on the Invoice Ninja Logo, wich is placed automatically.
You see it only when printing the pdf.
I tried 4 different printers.
Have you tried removing the transparency in the image file?
Hillel,
It’s not an image file, it’s a full color block
array [3]
0 {2}
canvas [1]
0 {7}
type : line
x1 : 0
y1 : 0
x2 : 600
y2 : 0
lineWidth : 200
lineColor : $primaryColor:#d0aa69
I’ll try one more time… in your first line you wrote: “I use a transparant png logo on my invoice.”
Have you tried removing the transparency from the png image?
Hi Hillel,
As i told before…
No, it’s a logo with transparant background, it also happens on the Invoice Ninja Logo, wich is placed automatically at the bottom of the invoice.
I think we’re going around in circles, maybe someone else can help…
Can i send you a scan of the printed pdf?
I believe I understand the problem.
In trying to help I’ve asked the same question four times but haven’t received an answer.
OK, i’ll try with a non transparant logo…
Great
Could be an issue with the PNG not supporting CMYK.
Would look fine on screen (RGB) but not when printed (CMYK).
If possible, create your logo with the same colour background as the colour block.
Invoice Ninja also offer a very reasonably priced white label option that will remove the Invoice Ninja logo.
