On my quote and invoice templates, I’ve pasted an html link. These don’t seem to be clickable in the pdfs. Is that normal behaviour? E.g. it is in this format.
View detailed proposal
You may need to include the URL rather than the link.
@david can you please advise if it’s supported?
If you are using Page Numbering this will prevent the rendering of links as clickable. If you disable the page numbering the links will become active again.
Thanks I will test this.
How do you disable page numbering?
In Settings > Invoice Design at the bottom is the option for page numbering
