Anyone else noticed that when using the “Light” email design that the border next to the “View Invoice” button doesn’t line up correctly as well as at the top right. Wondering if this is a bug?
v Latest Build - 2024-07-29
If you see the problem using the standard email design feel free to create an issue on GitHub.
OK Cool. I’ll do a test later without anything significant in the body we add quite a bit of custom text and I’ll add an issue if it persits…
Just for your information, this is not latest. Some self-host users seem to be having old index.html
files that need to be deleted. As far as I know, it doesn’t affect the instance, but doesn’t show correctly. Prior to the 2 releases in the past 24 hours, it had been 2024-08-15. It will now likely show 2024-08-22.
