When checking my Laravel scheduler logs I found out that it’s trying to connect to the database using, what I think is, the default user in Laravel projects (forge), thus bypassing the db connection variables in my .env file. N.B.: The db connection is working properly for the rest, or else the app would just not run (and it does run properly for the most part).
The sequence in the logs ends up with a TaskScheduler fail.
Any idea on how to fix that? The scheduler is running workers on the same user as the IN app, if that matters.
In Connection.php line 760:
SQLSTATE[HY000] [1045] Access denied for user 'forge'@'localhost' (using pa
ssword: YES) (SQL: select * from information_schema.tables where table_sche
ma = forge and table_name = accounts and table_type = 'BASE TABLE')
In Connector.php line 70:
ssword: YES)
2023-01-22 14:15:04 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:15:04 App\Jobs\Ninja\QueueSize ................... 9.79ms DONE
2023-01-22 14:20:02 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:20:02 App\Jobs\Ninja\QueueSize ................... 8.78ms DONE
2023-01-22 14:25:02 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:25:02 App\Jobs\Ninja\QueueSize ................... 7.46ms DONE
2023-01-22 14:30:02 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:30:02 App\Jobs\Ninja\QueueSize ................... 2.87ms DONE
2023-01-22 14:30:02 App\Jobs\Subscription\CleanStaleInvoiceOrder ... RUNNING
2023-01-22 14:30:02 App\Jobs\Subscription\CleanStaleInvoiceOrder 18.39ms DONE
2023-01-22 14:35:03 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:35:03 App\Jobs\Ninja\QueueSize ................... 2.73ms DONE
2023-01-22 14:40:03 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:40:03 App\Jobs\Ninja\QueueSize ................... 2.96ms DONE
2023-01-22 14:45:05 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:45:05 App\Jobs\Ninja\QueueSize ................... 6.05ms DONE
2023-01-22 14:50:03 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:50:03 App\Jobs\Ninja\QueueSize ................... 3.98ms DONE
2023-01-22 14:55:02 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 14:55:02 App\Jobs\Ninja\QueueSize .................. 15.06ms DONE
2023-01-22 15:00:02 App\Jobs\Util\ReminderJob ...................... RUNNING
2023-01-22 15:00:03 App\Jobs\Util\ReminderJob ................. 19.22ms DONE
2023-01-22 15:00:03 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 15:00:03 App\Jobs\Ninja\QueueSize ................... 4.81ms DONE
2023-01-22 15:05:03 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 15:05:03 App\Jobs\Ninja\QueueSize ................... 5.37ms DONE
2023-01-22 15:10:03 App\Jobs\Ninja\QueueSize ....................... RUNNING
2023-01-22 15:10:03 App\Jobs\Ninja\TaskScheduler ................... RUNNING
2023-01-22 15:10:03 App\Jobs\Ninja\QueueSize ................... 3.69ms DONE
2023-01-22 15:10:03 App\Jobs\Ninja\TaskScheduler .............. 18.36ms FAIL
