Hi there!
We’re running the self-hosted v5.7.58
We are currently using Invoice Ninja for estimates & invoices only, but are looking into a solution to keep track of our projects as well. I read through the documentation and experimented with a few features, but can’t seem to find a way to make things work like we would need it to work. I’ll try to describe it in detail, feel free to ask for additional info if needed!
This would be the ideal situation:
- We create an Estimate that makes use of Products (being an hour of a specific person, with a specific price & cost; these people are also Users and/or Suppliers in Invoice Ninja so they can write their time and send us their own invoices). For this example we’ll use a price of €100 for the customer and a cost of €80 for us. This means we take €20 in profits for each hour sold.
- Once approved, we convert it into a Project. This takes the budgeted hours from the Estimate and links them to the respective Users.
- Users write their time spent in Invoice Ninja
- We can follow up the status of a Project to check how it is going: a view on the time progress per User (is there an underspend or overspend?)
- Once the Project is finished, we create an Invoice for that Project
- This creates then Purchase Orders for each User that was assigned on the Project, based on the time that we billed the customer. Ideally these are then sent out to the respective Users and/or Suppliers.
Does that make sense? And is this possible?
Thanks for any help or information you can give!
