I upgraded from 5.3.66 to 5.8.50.
Interface looks great.
PDF did not work properly, but I saw other issues in this forum with that, so I guess it will be solved at some point. I tried all 3 options in the .env file, they all failed.
What I also found concerning was that in the tasks-kanban all previously invoiced tasks appeared again which gave a huge list. And there was no option to select on status in the kanban overview.
That option was availabe on the task-lists-view, so this could work if it is also on the kanban, but it was not there. Am using the tasks-kanban daily so that is hardly workable for me.
Is this a bug? or did I miss a setting somewhere?
Both issues combined made that I reverted to my backups of 5.3.66 for my daily usage of invoiceninja. I am probably able to repeat it, if I use a different subdomain for it. Let me know if you need me to do that and test some more.
