It sounds like you may have configured the app to queue the jobs in the database but the jobs aren’t being processed, please check you’ve added the artisan queue:work cron.
If you change it to sync it should start working but will be slow, you can leave it as database to keep it fast but you’ll need to have the queue running.
Quotes are only needed if there are unenclosed spaces (ie, “some value”).
