Hi, I’m getting a JS error when viewing PDF’s in our selfhosted installation, the pdf draws a blank screen:
Uncaught TypeError: Cannot read property 'length' of undefined
at Object.NINJA.invoiceDocuments (pdf.pdfmake.js:464)
at Object.NINJA.decodeJavascript (pdf.pdfmake.js:166)
at GetPdfMake (pdf.pdfmake.js:18)
at generatePDF (script.js:31)
at getPDFString (38:491)
at refreshPDF (38:1279)
at HTMLDocument.<anonymous> (38:495)
at u (jquery.js:3148)
at Object.fireWith [as resolveWith] (jquery.js:3260)
at Function.ready (jquery.js:3472)
To help narrow down the problem can you try disabling ‘Embed Documents’ on /settings/invoice_design#invoice_options to see if it helps (assuming it’s enabled).
No succes, still get the same error when viewing an invoice:
Uncaught ReferenceError: isMobile is not defined
at refreshPDFCB (invoice_design:1814)
at pdfmake.js:161
at r.<anonymous> (pdfmake.js:90)
at r.emit (pdfmake.js:22722)
at Array.<anonymous> (pdfmake.js:26065)
at r (pdfmake.js:23608)
I am seeing the same behaviour (blank report) with a similar error:
Uncaught TypeError: Cannot read property ‘length’ of undefined
at Object.NINJA.invoiceDocuments (built.js:26)
at Object.NINJA.decodeJavascript (built.js:26)
at GetPdfMake (built.js:1)
at generatePDF (built.js:1)
at getPDFString (6:492)
at refreshPDF (6:1275)
at HTMLDocument.<anonymous> (6:496)
at u (built.js:2)
at Object.fireWith [as resolveWith] (built.js:2)
at Function.ready (built.js:2)
at HTMLDocument.r (built.js:1)
‘Embed documents’ is always disabled.
I am not using docker.
I am available to test any suggestions or forward any logs that may help (the logs look OK to me).
