I am trying to update my app but am running into an error where it says routes-v7.php is not writable. www:data owns the entire directory so I am not sure why it can’t update. I found the update instructions for overwriting the files but am concerned about losing custom integrations and/or data. I looked through the files and can’t seem to find this file. Any ideas?
Most likely a command such as
php artisan optimnize
was previously run as a user other than www-data.
The fix here is to delete the contents of bootstrap/cache
Then reattemp the upgrade.
I just tried and now it says “update completed” but nothing actually updated.
Doesn’t php artisan automatically run from the user that calls it? I need to use sudo to run because otherwise it gives me this error:
In StreamHandler.php line 111:
The stream or file “/var/www/html/storage/logs/laravel.log” could not be opened in append mode: failed to open stream: Permission denied
I was able to update by deleting the .git folder. Unfortunately the update also overwrote my custom payment implementation and had to revert the snapshop until I figure out how to keep that from happening.
