I am able to see the setup page at: http://www.flexima.be/invoiceninja/public/setup
But when testing connection I can see in developer toolbar that setup page can not be found.
This is my htaccess file in public folder:
<IfModule mod_rewrite.c>
<IfModule mod_negotiation.c>
Options -MultiViews
</IfModule>
RewriteEngine On
# Redirect Trailing Slashes...
RewriteRule ^(.*)/$ /$1 [L,R=301]
# Handle Front Controller...
RewriteRule ^ index.php [L]
# Enable this to enforce https access
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://%{HTTP_HOST}/$1 [R,L]
</IfModule>
WHen hitting the submit in the bottom of the page I aonly see a white page.
Those are the last 10 lines of the webserver.
I think there is something wrong with my htaccess file, but no idea what
[Thu Dec 17 09:22:12 2015] [error] [client 188.189.6.218] unable to include “/403.shtml” in parsed file /opt/error_pages/403_antagonist.shtml
[Thu Dec 17 09:22:27 2015] [error] [client 188.189.6.218] File does not exist: /home/deb49902/domains/flexima.be/public_html/setup
[Thu Dec 17 09:22:27 2015] [error] [client 188.189.6.218] File does not exist: /home/deb49902/domains/flexima.be/public_html/404.shtml
[Thu Dec 17 09:22:27 2015] [error] [client 188.189.6.218] unable to include “/404.shtml” in parsed file /opt/error_pages/404_antagonist.shtml
[Thu Dec 17 09:40:33 2015] [error] [client 109.64.54.159] File does not exist: /home/deb49902/domains/flexima.be/public_html/setup, referer: http://www.flexima.be/invoiceninja/public/setup
[Thu Dec 17 09:40:33 2015] [error] [client 109.64.54.159] File does not exist: /home/deb49902/domains/flexima.be/public_html/404.shtml, referer: http://www.flexima.be/invoiceninja/public/setup
[Thu Dec 17 09:40:33 2015] [error] [client 109.64.54.159] unable to include “/404.shtml” in parsed file /opt/error_pages/404_antagonist.shtml, referer: http://www.flexima.be/invoiceninja/public/setup
[Thu Dec 17 09:41:39 2015] [error] [client 109.64.54.159] File does not exist: /home/deb49902/domains/flexima.be/public_html/favicon.ico
[Thu Dec 17 09:41:39 2015] [error] [client 109.64.54.159] File does not exist: /home/deb49902/domains/flexima.be/public_html/404.shtml
[Thu Dec 17 09:41:39 2015] [error] [client 109.64.54.159] unable to include “/404.shtml” in parsed file /opt/error_pages/404_antagonist.shtml
You shouldn’t need to make any changes to the .htaccess file.
There is a problem with the ‘Test Credentials’ button which is causing those errors, however I think the problem you’re seeing when you click save is a separate issue.
You could try setting everything to 777 to see if it’s a permissions issue, clearly not the best way to run the app but it could help identity the problem.
