Version: v5.12
Environment: Self-Hosting
Have you inspected the logs? Yes, no error… bc there are no errors. When I save, Invoice Ninja returns “Saved”
Describe the bug
I am currently running the latest version of Invoice Ninja (v5.12.0), and I’m experiencing a strange issue that I haven’t been able to resolve, even after searching through the forum discussions.
Here’s a summary of the problem:
When I create a new quote from my desktop, it saves correctly and immediately.
However, when I edit that quote to make adjustments, the changes do not appear in the desktop view after saving.
Strangely, if I open the same quote on my mobile phone (iOS app), the updated information is displayed correctly.
Additionally, if I make edits in the iOS app and send the quote to a customer, both the customer and I can see the updated version without any issues. However, if I open that same quote on my desktop immediately after, the changes are not reflected.
This issue appears to be limited to viewing updated quotes on the desktop.
The only workaround I’ve found is to clear the server-side cache using cPanel. After doing that, the desktop version shows the correct and updated information.
At first, I suspected this could be related to a CRON job issue. However, since all updates made via the iOS app are saved and sent correctly without delay, I now believe the issue is related to caching rather than CRON jobs.
It seems like a browser or session cache issue specific to the desktop. I would appreciate any insight or guidance on how to fix this permanently without having to clear the cache manually every time.
Thank you for your time and support.
FYI: I have been a long-time user of your system since 2015. I saw absolutely ALL the hard work you guys put into it. You guys make a great team.
Best,
Robert B
