Issue with portal translation
I use Invoice Ninja v4.5.32
It is possible to force the UPPER CASE event when it is a letter with an accent ?
I means it is possible for TÂCHE (look at the top right)
why not for CRÉDIT and RELEVÉ ??
Sorry, I’m not sure.
It may be related to the specific font we’re using, you can test changing it on Settings > Invoice Design.
you means in Settings → Client Portal ???
I don’t see how I could change the font unless I did in the CSS
Maybe I’m wrong (not a WebdeV) :stuck_out_tongue:
but it seams to be a typo and not an error with the font
If it’s a typo you should be able to fix it in the translations
https://www.transifex.com/invoice-ninja/invoice-ninja/
