General hint for self-hosted Invoice Ninja users:
INmanage is basically the maintenance layer for Invoice Ninja and helps you mitigate any issue.
From one CLI you can:
run extensive health checks
fix, install & configure
update safely with automatic backups + rollback
backup & restore
monitor & receive notifications
migrate instances
Setup takes around 2β3 minutes per host.
Biggest benefit: less maintenance, less uncertainty, fewer surprises.
The health system checks your Invoice Ninja stack proactively. Before small issues become actual problems.
https://github.com/DrDBanner/inmanage
Itβs also LLM-friendly, so coding agents can safely inspect and operate an installation via SSH, health checks and dry-runs.
