I’m trying to use a custom Invoice field named “project” for quotes & invoices. For some reason, it doesn’t show up in the Hipster template PDF’s. (It does show in all the other templates).
That design uses a different approach to laying out the fields, you’d need to either use a custom design and manually add the field or drag it to a different section on Settings > Invoice Design > Product Fields.
Thanks Hillel
