After updating with zip file and running the /update command it gives me this error:
SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name ‘logo’ (SQL: alter table accounts add logo varchar(255) null, add logo_width int unsigned not null, add logo_height int unsigned not null, add logo_size int unsigned not null, add invoice_embed_documents tinyint(1) not null default ‘0’, add document_email_attachment tinyint(1) not null default ‘0’)
Which is correct, column name ‘logo’ already exists in table ‘accounts’.
November 29, 2016, 2:45am
It looks like there was a problem running the database migrations.
Can you check storage/logs/laravel-error.log for the past few errors.
This is the error in that file (masked my hostname with *****):
[2016-11-29 13:07:51] production.ERROR: Illuminate\Database\QueryException [HY000] : /vendor/laravel/framework/src/Illuminate/Database/Connection.php [Line 729] => SQLSTATE[HY000]: General error: 1005 Can’t create table ‘ninja.#sql-4a2_12020e ’ (errno: 150) (SQL: alter table documents add constraint documents_account_id_foreign foreign key (account_id) references accounts (id) on delete cascade) {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:"",“method”:“GET”,“url”:" /public/update",“user_agent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2840.98 Safari/537.36”,“ip”:“82.173.37.225”,“count”:1} []
i tried again fresh, no error in the browser this time just ‘Whoops, looks like something went wrong.’.
in laravel log:
[2016-11-29 14:06:33] production.ERROR: exception ‘PDOException’ with message ‘SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘migrations’ already exists’ in *****facturen/vendor/laravel/framework/src/Illuminate/Database/Connection.php:457 Stack trace: #0 *****facturen/vendor/laravel/framework/src/Illuminate/Database/Connection.php(457): PDOStatement->execute(Array) #1 *****facturen/vendor/laravel/framework/src/Illuminate/Database/Connection.php(722): Illuminate\Database\Connection->Illuminate\Database{closure}(Object(Illuminate\Database\MySqlConnection), ‘create table m…’, Array) #2 *****facturen/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->runQueryCallback(‘create tablem…’, Array, Object(Closure)) #3 *****facturen/vendor/laravel/framework/src/Illuminate/Database/Connection.php(458): Illuminate\Database\Connection->run(‘create table m…’, Array, Object(Closure)) #4 *****facturen/vendor/laravel/framework/src/Illuminate/Database/Schema/Blueprint.php(83): Illuminate\Database\Connection->statement(‘create tablem…’) #5 *****facturen/vendor/laravel/framework/src/Illuminate/Database/Schema/Builder.php(229):
Should i remove the ‘migrations’ table?
November 29, 2016, 3:33am
5
To start fresh you’ll want to recreate the database.
And export invoices etc from old version so i can import in the new version? Will the import work in 2.8.1 from ‘old’ 2.5.0.3 export files?
November 29, 2016, 3:41am
7
No, to transfer your data you’d need to export to our latest version.
We’re working on a new minor release later today, we’ll include a fix which may help.
Note: you’ll need to comment out lines 13 to to 22 in database/migrations/2016_03_22_168362_add_documents.php
Okay, thank you for your support. I’ll wait for the new release.
p.s. tried to comment out the lines but got another error:
SQLSTATE[HY000]: General error: 1005 Can’t create table ‘ninja.#sql-4a2_120a92 ’ (errno: 150) (SQL: alter table documents add constraint documents_account_id_foreign foreign key (account_id) references accounts (id) on delete cascade)
November 29, 2016, 3:53am
9
You’ll need to comment out those line using the next release.
November 29, 2016, 8:50am
10
We’ve released v2.8.2, hopefully it will help with this problem.
https://dl.dropboxusercontent.com/u/2909575/ninja-v2.8.2.zip
I have tried but I can’t get it to work.
Tried with original database from 2.5.0.3 and unzipped the 2.8.2 version, commented out lines 13 to to 22 in database/migrations/2016_03_22_168362_add_documents.php
But the same error appears:
SQLSTATE[HY000]: General error: 1005 Can’t create table ‘ninja4.#sql-4a2_124faf ’ (errno: 150) (SQL: alter table documents add constraint documents_account_id_foreign foreign key (account_id) references accounts (id) on delete cascade)
November 29, 2016, 10:08pm
12
yes it is up to date, to be sure i copied the file but still the same error. If i try to access (without /update) I get:
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘ninja4.companies’ doesn’t exist (SQL: select * from companies where companies.id is null and companies.deleted_at is null limit 1
with /update i get:
SQLSTATE[HY000]: General error: 1005 Can’t create table ‘ninja4.#sql-4a2_12abf7 ’ (errno: 150) (SQL: alter table documents add constraint documents_account_id_foreign foreign key (account_id) references accounts (id) on delete cascade)
November 30, 2016, 9:41pm
14
Can you check the documents table exists by running select * from documents
the table exists but it is empty, table structure (if that helps) is:
public_id int(10) unsigned DEFAULT NULL,
account_id int(10) unsigned NOT NULL,
id int(10) unsigned NOT NULL AUTO_INCREMENT,
user_id int(10) unsigned NOT NULL,
invoice_id int(10) unsigned DEFAULT NULL,
expense_id int(10) unsigned DEFAULT NULL,
path varchar(255) COLLATE utf8_unicode_ci NOT NULL,
preview varchar(255) COLLATE utf8_unicode_ci NOT NULL,
name varchar(255) COLLATE utf8_unicode_ci NOT NULL,
type varchar(255) COLLATE utf8_unicode_ci NOT NULL,
disk varchar(255) COLLATE utf8_unicode_ci NOT NULL,
hash varchar(40) COLLATE utf8_unicode_ci NOT NULL,
size int(10) unsigned NOT NULL,
width int(10) unsigned DEFAULT NULL,
height int(10) unsigned DEFAULT NULL,
created_at timestamp NULL DEFAULT NULL,
updated_at timestamp NULL DEFAULT NULL,
PRIMARY KEY (id)
November 30, 2016, 9:45pm
16
Try commenting table creation from the migration file.
I did and documents table is gone now. new error is:
SQLSTATE[HY000]: General error: 1005 Can’t create table ‘ninja4.#sql-4a2_12adc4 ’ (errno: 150) (SQL: alter table companies add constraint companies_payment_id_foreign foreign key (payment_id) references payments (id))
Seems like there is something wrong with my database or maybe permission problem or something? Is there a query i can try in phpmyadmin to check if that works to find the problem?
November 30, 2016, 9:52pm
18
Maybe the foreign keys were already added, you can run this query to check
show create table documents;
im going from error to error, i feel like im doing something stupid. Maybe my update workflow is wrong.
I have 2.5.0.3 in folder A
I unzip 2.8.2 in folder B
Move files from B to A and overwrite
run example.com/folderA
Should i try another approach? edit a file in folderb and run /folderb for example?
sorry to bother you so much…
November 30, 2016, 10:30pm
20
That should work. I think the next step is trying to comment out the foreign keys in the migration file.
