Hi there everyone!
I am contemplating updating from v4 to v5 and wanted to ask if there’s an established update process that I could read and follow. Any info would be greatly appreciated.
Thanks for your time!
Hi there everyone!
To upgrade from v4 you need to install v5 as a separate app and then use the migration tool in the latest version of v4 on Settings > Account Management.
Thanks so much! After I do this, if I want to change my new install to reflect the old directory, are there any files or db elements I need to change? For instance, if I install v5 in directory new
and after migration, want to change the directory from new
to old
(where v4 was), do I need to modify any files or database entries to reflect the new path for v5?
You need to change the APP_URL value in the .env file and then run php artisan opttimize
to change the app URL
