Hi
Is there a way to add simple notes to each clock entry under a task? Currently we have start date, start/end time and the duration fields.
thanks
Hi
thanks
It isn’t supported, you would need to create separate tasks for each note.
Thanks, while creating separate tasks is ok for this, it really clutters invoices, because one might end up working on 5 different things for the same project within the same general task, so that means 5 invoice entries for that same day.
