Invoices in Dashboard
New to using this program, using the web based version, Pro trial. On the dashboard I find an amount for invoices already paid. Why is this? It seems to be two out of about a dozen that have been paid are hung up in the “Invoices” section of the dashboard. Thanks
If you’d like to email a screenshot of your dashboard to [email protected] we can try to help you understand it.
You may also want to compare it with the desktop version.
Thanks @hillel for the quick reply
The invoices amount includes paid invoices, if the invoices are unpaid they will also be included in the outstanding amount.
