Version ie <v5.10.30>
Checklist
- Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja?
- Have you searched existing issues?
- Have you inspected the logs in storage/logs/laravel.log for any errors?
Describe the bug
Steps To Reproduce
Expected Behavior
Additional context
Screenshots
Logs
Health Check
System
Email: smtp
queue: database
PDF: SnapPDF PDF Generator
Database Connection
passed
PHP
web: 8.2.26
cli: PHP 8.2.26 (cli) (built: Nov 21 2024 18:05:01) (NTS)
Memory: 512M
API: 5.10.58
Hi there,
I have recently migrated from v4 to v5 Docker and all worked fine. Now I need to change the language from English to French. I addressed this under the section Settings/Localization which resulted in “Successfully saved settings” popup but nothing changed. All side menus (and everything else) are still in English. I have pulled the latest docker image and restarted the container, cleared browser cache, used different computers etc. No luck.
Only the system logs started recording in French.
Any advice here?
Thank you
ck
