On a fresh install and the cron job running on schedule I keep getting a 404 error on the admin side after the jobs run. The apache2 errors logs don’t show what that error is from as it is executing properly. What I am finding is i believe the php artisan schedule:run also runs the php artisan optimize command every so often causing my 404 error for me. To resolve it I clear out the bootstrap/cache/* directory to get this running good again and after some time the 404 error comes back later after the schedule runs again. Right now it seems to be a cache issue.
Earlier I was dealing with the client portal being blank and nailed it down after using firefox inspection that the livewire url was wrong, correct this and did a php artisan livewire:publish to update the url links, which in turn resloved my orginal 404 error.
Now looks like it is now a cache issue and the optimize command invokes it instead of resolving it. Please advise in what direction i should look at. I just have to keep cleaning out the cache directory manually to keep me going at the moment. Luckily my install is testing/part production test to solidify this install.
