Hi i am get error something went wrong on
On
It docker instal
Are there any errors in the logs?
Hi Winch log file larvel ?i can posts it content
It show mostly on invoice page if thatâs help also
The Laravel logs are in storage/logs
[2023-11-09 21:30:22] production.ERROR: Cannot access private property horstoeko\zugferd\entities\basic\udt\TextType::$__value {âuserIdâ:1,âexceptionâ:"[object] (Error(code: 0): Cannot access private property horstoeko\zugferd\entities\basic\udt\TextType::$__value at /var/www/app/vendor/jms/serializer/src/Accessor/DefaultAccessorStrategy.php:90)
#0 /var/www/app/vendor/jms/serializer/src/Accessor/DefaultAccessorStrategy.php(96): horstoeko\zugferd\entities\en16931\udt\TextType::JMS\Serializer\Accessor\{closure}(Object(horstoeko\zugferd\entities\basic\udt\TextType), â__valueâ)
#1 /var/www/app/vendor/jms/serializer/src/GraphNavigator/SerializationGraphNavigator.php(262): JMS\Serializer\Accessor\DefaultAccessorStrategy->getValue(Object(horstoeko\zugferd\entities\basic\udt\TextType), Object(JMS\Serializer\Metadata\PropertyMetadata), Object(JMS\Serializer\SerializationContext))
#2 /var/www/app/vendor/jms/serializer/src/XmlSerializationVisitor.php(333): JMS\Serializer\GraphNavigator\SerializationGraphNavigator->accept(Object(horstoeko\zugferd\entities\basic\udt\TextType), Array)
Also maybe it related my dock env edit url just wonder i changed docker app url to use ip could that be related?
I could post full logs file some where if any help Thanks Hillel
https://pastebin.pl/view/b9ea493f# full logs if more help
Any suggestion? Could be url app url related
Which version
Was it working previously.
This is a very unusual error and it looks to be originating from the package itself.
New install maybe was something i edit in dock fil?
Can app url be? A ip address?
Iâm not sure, the error does not indicate an APP url issue thouâŚ
Are you using the standard Docker file provided?
Yes with few edit
Noting thay could think would cause that
The dock file work fine test machine acsss via local host
If restore data out ones get error maybe they something i dont know why it would matter
Just to confirm, you also have einvoicing turned on?
I dont think so i just restored data i had made when i was testing into new install with out setting
No errors yet? Where is einvoce?
Setting
I kept other docker install so if some setting i can test see maybe issues or bug or something?
I just tested in my docker turning einvoicing on and off and could not reproduce this.
You can toggle EInvoicing in Settings > Email Settings
I will check the original install on my new one i have turned off
Maybe that what is e invoice feature do?
On my backup it was on?
Explain why restore backup with out setting worked
