We are trying to use "“Invoice Total” field inside the invoice. Even though, we chose it inside “Invoice Label” tab and “Invoice Fields” Tab, it doesn’t appear in the invoice. Other fields such as “Balance due”, etc. are being displayed correctly.
Thanks for your help.
We are using v4-self hosted.
Sorry, I’m not sure. You may want to consider upgrading to v5, v4 is no longer actively supported.
