If invoice terms contents is too long, it will overlap the invoice footer
This seems to only occur to invoices with white label.
I have the same problem. I get 1 invoice on two pages. The terms appear with the values ​​on the second page. Is there any way to correct this?
can you show a screenshot.
@david Here’s mine.
As a side note: Above screen shots show the “Unit Cost” and “Quantity” columns being left aligned, which doesn’t really make a nice table. Just tried; the same is true for the “Tax” column, if present. Can those be made right aligned while you are at it?
This looks like an overflow issue, you can reduce the font to try and get everything onto a single page.
we’ve played around with this and the header text is in the least offensive position for the majority of people. The alignment can be customized with CSS.
is this the business template?
Yes @david, its the business template.
Hello david! Thank you for helping. Set the font to 5, the smallest and it doesn’t work. The same remains in two pages when the terms are a lot of text. Look for a previous invoice, before buying the whitelabel printing with Phantom JS, if you leave it at 1 page. In system Health it says that I have 439 jobs pending.
Ok, I have played around with this for a bit. I have derived my invoice design from “Plain”, and not looked at any other designs, so I don’t know how this would fit into other designs. But I’d suggest the following change to the “Plain” design:
*** includes.orig Tue Feb 8 04:41:33 2022
--- includes.test Thu Mar 3 14:35:59 2022
*** 85,110 ****
- [data-ref="table"] > thead {
- text-align: left;
[data-ref="table"] > thead > tr > th {
padding: 1rem;
background-color: #e6e6e6;
! [data-ref="table"] > thead > tr > th:last-child {
! text-align: right;
[data-ref="table"] > tbody > tr > td {
border-bottom: 1px solid #e6e6e6;
padding: 1rem;
! [data-ref="table"] > tbody > tr > td:last-child {
#table-totals {
page-break-inside: avoid;
--- 99,131 ----
padding: 1rem;
+ text-align: right;
! [data-ref="table"] > thead > tr > th:nth-child(1) {
! text-align: $dir_text_align;
+ [data-ref="table"] > thead > tr > th:nth-child(2) {
+ text-align: $dir_text_align;
padding: 1rem;
+ vertical-align: top;
! [data-ref="table"] > tbody > tr > td:nth-child(1) {
+ [data-ref="table"] > tbody > tr > td:nth-child(2) {
#table-totals {
*** 127,131 ****
#table-totals>.totals-table-right-side>*> :nth-child(1) {
! text-align: "$dir_text_align";
margin-top: .75rem;
padding-left: 7px;
--- 148,152 ----
margin-top: .75rem;
padding-left: 7px;
This makes all but the first two table columns right-aligned to make nice number columns, first two columns follow $dir_text_align. Also includes a vertical-align: top; to make table rows top-aligned improving readability for lines with long, multi-line descriptions. (This was also requested by another user a while back.)
While playing with it I also discovered text-align: "$dir_text_align"; doesn’t work, the quotes need to go. So fixed this as well. This needs to be fixed in other designs too.
If you have 439 jobs pending:
egrep QUEUE_CONNECTION /path/to/invoiceninja/.env
Hi Xoo, Thank you!
Sorry, I’m not very knowledgeable about what you’re asking. It would have to tell me step by step what I should do to show the results.
BROADCAST_DRIVER=log
LOG_CHANNEL=stack
CACHE_DRIVER=file
QUEUE_CONNECTION=database
SESSION_DRIVER=file
SESSION_LIFETIME=120
REDIS_HOST=127.0.0.1
REDIS_PASSWORD=null
REDIS_PORT=6379
MAIL_MAILER=log
MAIL_HOST=
MAIL_PORT=
MAIL_USERNAME=
MAIL_PASSWORD=
MAIL_ENCRYPTION=tls
MAIL_FROM_ADDRESS=
MAIL_FROM_NAME=
POSTMARK_API_TOKEN=
REQUIRE_HTTPS=true
GOOGLE_MAPS_API_KEY=
ERROR_EMAIL=
TRUSTED_PROXIES=
NINJA_ENVIRONMENT=selfhost
PDF_GENERATOR=hosted_ninja
NINJA_HOSTED_PDF=true
PHANTOMJS_KEY=“a-demo-key-with-low-quota-per-ip-address”
PHANTOMJS_SECRET=“secret”
UPDATE_SECRET=secret
QUEUE_CONNECTION=database means you are trying to use the queue, but the huge number of pending jobs tells me that doesn’t work as it should. Can you tell how your cron job(s) are set? (Or are you seeing a red triangle in the bottom left corner telling you to set up cron?)
It would perhaps be a good idea to seek some Linux help here.
thanks for the reference of $dir_text_align, this is fixed in the next release
I think everything is back to normal.
The invoices continue to appear on two pages when there is enough text in the terms field. In any case, I would have to add them manually with Adobe Acrobat. Thank you very much for all the help!
