Hi Everyone,
Somehow I managed to mess up my invoice template formatting. (see example)
How can I reset all my templates back to normal? Most seem to be messed up somehow. I’m not sure what files to copy over?
Thanks, Walter
Hi Everyone,
Thanks, Walter
Are you using a custom design? Have you tried switching to a standard one.
Hi Hillel,
No, these are all the stock templates. I was able to get it somewhat fixed by editing it. I’m not sure if the CSS is saved in the database or in a file? I tried copying all the files from a fresh download that looked like it may be part of templates. Still did not work.
Thanks,
Walter
Does changing to a different design help?
