I am using self hosted v5.0.40-C33 on chrome v87.0.4280.88
When I open Invoice design → customize & preview, on the right side I get error of faild to load pdf.
Same issue with Edge browser.
Hey there,
Thanks for reporting this to us. Can I know the environment you’re using? Have you configured the server yourself? Are you using Docker?
Also, can you please post the output of the storage/logs/laravel.log file. There should be an error message.
Thanks!
I installed and configured server by myself. It is running ubuntu 20.04 php7.4 and nginx.
No errors in the log: https://i.imgur.com/uozQqLl.png
All right. Can you tell me what’s the value of PHANTOMJS_PDF_GENERATION variable in .env file?
There are three variables related to phantom:
PHANTOMJS_PDF_GENERATION=true
PHANTOMJS_KEY=‘a-demo-key-with-low-quota-per-ip-address’
PHANTOMJS_SECRET=secret
One thing you could try & I’d suggest that is switching to local PDF making system.
Do the following:
See if that works for you ![]()
After checking for missing dependencies I got this:
libgbm.so.1 => not found
Installed it and done the rest of your instruction. It works now!
Thank you
Thanks for letting us know!
Cheers
