I use the default clean invoice design.
Coming from v4, in v5 the line breaks of my tasks get ignored. This was not the case in v4.
The workaround I found was to insert two line breaks. Is that the intended behaviour?
It should help to disable markdown on Settings > Account Management.
v5.3.75-C77 is my version.
Disabling markdown did the trick
