Invoice / Quote Templates
Hi
I recently did a backup and restore of the data on a new hosting environment and for some reason all my old invoices and quotes have not retained the template look that I setup for them.
Its only when creating new invoices or quotes does it use the templates I created.
Its like all the old invoices and quotes have defaulted back to the defaulted template for when first setting up the installation.
Is there something I can run so they all show the invoice and quote templates i created?
v5.12.27-W174
Did you use mysqldump to transfer the database?
No I used the Invoice Ninja internal export and import facility.
If you still have the old system available it may help to try mysqldump instead.
Unfortunately I don’t, the old system was deleted a few weeks ago
I suggest asking in a discussion on GitHub
