Hi
Is there a way to add a project and an expense on the same invoice? Here’s an example to illustrate my issue:
I designed a sign for a client (which would count as project) but wasn’t able to print it at home so I had it done at a printery. That would have been an expense. However while I can use Invoice Ninja to create invoices from the project or the expense separately, there doesn’t seem to be a way to automatically add in either, especially when it’s connected to the client…so if I create the invoice from the project, I can’t include the expense that’s already entered under expenses. I would have to manually have to type it in. I guess there are times when invoicing the expenses alone would be cool but in this case I don’t really want to do two separate invoices for the same client.
What is the solution?
