Invoice number error in automation
I recently opened an account with Invoice Ninja and manually entered my existing invoices with numbers ranging from 1001 to 1750
After completing this process, I set up an automation to generate new invoices in Invoice Ninja whenever there is a new charge in Stripe.
Problem:
The automation is working, but it is creating new invoices with numbers starting from 0001, 0002, 0003, etc., instead of continuing from my last manually entered invoice (1750).
How do I solve it?
How to fix the automation?
How to make the new invoices run according to the current invoice number?
You can fix this by adjusting the counter on Settings > Generated Numbers/
