I am using the Self-Hosted version of InvoiceNinja and have installed the MacOS application on my Mac.
There is an option to add a widget from InvoiceNinja, but when I do so, it just says this.
“Please adopt containerBackground API”
Does anyone know how to get this to work?
January 7, 2025, 8:22pm
Which version of macOS are you using?
MacOS Sequoia 15.2
MacBook Pro Intel
Currently up to date (system and the app from the app store)
January 9, 2025, 6:20am
4
Thanks, we’ll work to fix this in the next release of the app.
When I click on it, this link pops up
Fred10
July 25, 2025, 9:12am
6
Same issue on Mac M1 Tahoe 26.0 (beta4)
July 25, 2025, 11:22am
7
Thanks, we’ll look into this for the next macOS release
August 17, 2025, 10:44am
9
Quick update…
A separate problem with the widget has prevented us from deploying the latest release to the App Store. For now we’ve needed to temporarily disable the widget, we hope to add it back in the future.
