How i can change (translate) Invoice Ninja labels?
I will like to change Balance Due
v5 Version.
the option in settings > localization > custom labels, will not work.
and it is same for all other labels:
Can we change this text Invoice issued to inside settings or does it needs to be changed in invoice HTML?
Regards
@ben do you have any thoughts?
ben
3
I believe it’s same issue as Issue in product-table display - #9 by Jazz. Please follow the thread there.
As I can see on images at Jazz topic.
labels show fine there?
BUMP.
At last version, I still have same issue.
Invoice number
Invoice Date
Invoice Total
Balanced Due
Invoice issued to:
Net
Translates:
SLACK: Slack
david
6
What are you using for the “keys”
I cannot recreate this at all if I use the correct translation key.
For example. Net should have a key value of net_subtotal
Can you please tell me where i can find “keys” ?
I will like to translate this labels:
Invoice number
Invoice Date
Invoice Total
Balanced Due
Invoice issued to:
Net
Edit:
It can be founded here: https://github.com/invoiceninja/invoiceninja/blob/master/resources/lang/en/texts.php
Thanks, i was so blind
