Invoice Issues/Suggestions
Now that I have begun to use an explore Invoice Ninja a bit, I have a couple of suggestions for improvements on invoices:
1.) There needs to be better integration with credits. Right now, I can apply a credit to an invoice using a “payment” but I cannot do this without applying a payment from the customer as well. You cannot apply the credit in advance. The system will not allow you to have a $0 payment. There should be a way to apply the credit in advance of payment.
2.) On recurring invoices, the standard terms (ie: Net 30) are not applied. Instead, you apply a due date during the month. You should be able to apply your standard terms. Some customer may have longer terms than 30 days which then could not be applied.
If you’d like to see changes in the app feel free to create issues on GitHub.
That said, I believe #2 is already supported.
