I have a few hundred invoices I’m trying to import from Pancake, most are failing with the error " The following records failed to import, they either already exist or are missing required fields."
I deleted all invoices prior to importing, so I know it’s not an existing invoice issue.
What fields would be required? Also, if they were required, wouldn’t the import fail on all of them, given Pancake has them all formatted in the same manner?
I’m self hosting on v 4.5.12. No errors are being logged in the laravel-error.log file at all.
I also just imported from Pancake. The first last name for mine works fine. Just that all the resulting address fields is empty. Might be because Pancake’s Address is a single multi-line field, but in InvoiceNinja it is multiple fields of Street, Apt/Unit, City, etc.
