When exporting an invoice, or group of invoices to .csv, in a self-hosted environment ,the product field is missing. I don’t know if this is by design but it seems like it should be there because well, everything else is except anything related to the product such as Item and Description.
We’ll look into adding this in the future…
We currently show one row per invoice, we’d need to show each invoice multiple times if it has multiple line items. Our CSV import supports this so it would make sense for the export to match.
If importing is supported, can you provide an example of what the columns should be, cause really that’s all I need. I was just using the export as an example of how the columns were setup.
After you upload the file you can map the columns.
