Recently, ninja has started to name my invoices as follows: Invoice_Invoice_number
example Invoice_Invoice_3324.pdf
it used to be just Invoice_3324.pdf
Can’t find where to fix this…
Which version of the app do you see in the about dialog?
v5.7.57-L158
I need to update the server so I can upgrade PHP. Can’t go to the next version because my PHP is not recent enough. Which may mean I have to do a release upgrade on the server itself, because apt is not pulling the latest PHP.
I believe this issue is caused by the Linux app, it should be corrected in the latest version.
Note: the Flatpak Linux app is often ahead of the Snap app.
