Hey,
When I add to many invoice lines then it overlaps the foot note.
How can I solve that?
Hey,
You may be able to solve it using a custom design by increasing the value for the bottom footer on the ‘Margins’ tab
Ok, thanks for the help but is this something normal? Isn’t this supposed to be correct out of the box?
There can be a problem depending on the design selected and the length/height of the footer
I’ve checked the margin of the model “Business” and the top is by default put at “-20”. That explains why it overlaps.
Maybe it’s best to take this in consideration for the next update?
