I am unable to customize invoice. I go to invoice design and select customization, then includes. I make the css changes to my liking then try to save. I get this error:
422: Unprocessable Content • The given data was invalid.
Sorry, I didn’t see the name field to assign to changes.
Once I gave it a name the changes went thru.
Thanks for working with me on Christmas … Hillel.
I guess there is no way to change the download name of the invoice?
It would be nice to have the JS - showDirectoryPicker().
That way you could direct the download folder and have a chance to rename the file.
Hillel - am I suppose to be creating a new topic each time I reach out?
I open another topic and sent to David with no response.
So I’m back to you.
Is it safe to run Invoiceninja with Xampp as localhost only.
I just need an Invoicing generator and the ability to run an annual invoice report for taxes.
I will only be using my personal computer.
I do not need to access the database on the web in other locations.
I will not be using my phone to connect to the database.
I will not be using the email function, I will be using Thunderbird for emailing.
If so, is there any security settings I need to change?.
Since you’re running an older version there should be an update option. If there are any problems you can manually update by copying over the latest release ZIP.
