Is there any way at all to add in a custom field for a Title on the invoice?
Basically a separate field that can be up top somewhere to give the invoice a unique title.
I am on the Hosted plan.
Thanks!
Thanks!
You can accomplish this using the customize design page:
https://app.invoiceninja.com/settings/customize_design
For example, with the clean design you can try changing $entityTypeUC to $customTextValue1.
Note: to use this you’d also need to specify a custom invoice field:
https://app.invoiceninja.com/settings/invoice_settings#invoice_fields
GREAT! That works!
Thank you!!
Is there a way to also keep the entityTypeUC?
can I make another spot for that? maybe in that same area on the invoice, but flush against the right side?
Thanks!
I found another spot for the entityType.
In the Clean Template, there was an empty text field next to the Client Details, so i put it in there.
I styled it to align right. Increased the font size, made it bold and now it looks nice! woooo!
Thanks again for this awesome App!!!
Great to hear!
