After migrating from v4 to v5 I have two problems when creating invoices and generating the invoice PDF.
the footer is not at the bottom of A4 paper anymore. It comes directly under the invoice details and looks not professional anymore. → how can we really get the footer at the bottom of the invoice page?
I’m missing the custom labels name on the invoice. I need to add IBAN , BIC and BTW (belgian for TAX) labels when using custom invoice fields.
It’s possible to add the labels using a custom design. @david@ben this seems to be a very common request, I think we should try to work on a simpler solution.
Yes it is because the Project name already uses the markdown. It looks like you can only use it once. .(e.g. when you create an invoice from the running projects ## → title ### → consumed time )
