Just migrated to V5 and generated a new Integromat api key. When I go to Integromat to modify a scenario I get the message:
Failed to verify connection
Is this a V5 problem? Any updates on this?
I believe you’ll need to recreate the integration using the v5 version of Integromat.
Where can I find the V5 version of Integromat?
Sorry, you’ll need to ask Integromat directly.
I went into an Integromat scenario and added Invoice Ninja again and now I have (below in the favorites) an icon with Invoice Ninja V1 and Invoice Ninja V2. Guess the V2 is for the V5 version of Invoice Ninja.
I can connect now but there are some issues still there. Most noteably that there are no fields for a contactperson. I contacted Integromat but post it here if someone else uses Integromat too. Then they should better wait a while with migrating.
Sorry for the delay! We manage the Zapier integration ourselves but other solutions are managed by their respective teams.
I understand. I’m just keeping this open so that other with an Integromat integration know before they migrate. I’ll try to update this with information I get from them.
