How can I integrate invoice ninja with quikbooks, I know zapier helps to work between both applications however. Would it be able to transfer all the data or only once its triggered from a certain point. Please advise. Thanks
Zapier is typically used to transfer data as it’s created.
You may be able to transfer past data using CSV.
