Warning: require(/home/clients/15f153e506bfcee335069cf4812c82/sites/invoices2.mydomain.ch/public/…/vendor/autoload.php): failed to open stream: No such file or directory in /home/clients/15f153e506bfcee335069cf4812c82/sites/invoices2.mydomain.ch/public/index.php on line 26
Fatal error: require(): Failed opening required ‘/home/clients/15f153e506bfcee335069cf4812c82/sites/invoices2.mydomain.ch/public/…/vendor/autoload.php’ (include_path=’.:/opt/php7.4/lib/php’) in /home/clients/15f153e506bfcee335069cf4812c82/sites/invoices2.mydomain.ch/public/index.php on line 26
I get this error if i visit invoices2.mydomain.ch or /setup or /public…
How are you installing the app? I think you might be missing the vendor files which are included with the zip but need to be installed with composer if using the code from GitHub.
I tried to run this: ```
composer install --no-dev -o
But i keep getting this error:
Loading composer repositories with package information
Installing dependencies from lock file
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Installation request for jean85/pretty-package-versions 2.0.4 -> satisfiable by jean85/pretty-package-versions[2.0.4].
- jean85/pretty-package-versions 2.0.4 requires composer-runtime-api ^2.0.0 -> no matching package found.
Problem 2
- sentry/sentry 3.3.1 requires jean85/pretty-package-versions ^1.5|^2.0.1 -> satisfiable by jean85/pretty-package-versions[2.0.4].
- Installation request for sentry/sentry 3.3.1 -> satisfiable by sentry/sentry[3.3.1].
Potential causes:
- A typo in the package name
- The package is not available in a stable-enough version according to your minimum-stability setting
see <https://getcomposer.org/doc/04-schema.md#minimum-stability> for more details.
- It's a private package and you forgot to add a custom repository to find it
