Installing SSL Certs
Version ie <v5.11.18>
Self-hosted through truenas community train.
i cant find step by step instructions on how to go about adding a ssl cert. for i can process payments. may i suggest making this ability to change and update ssl certs inside the UI.
Although I agree it’d be great I’m not sure it’s possible, SSL is configured at the server level.
certs in a truenas enviorment are easily installed and then called for later on in the setup wizard of a docker
Feel free to create an issue on GitHub to request the feature.
