If I’m using InvoiceNinja docker container, does it require me to install a db also such as mariadb?
                    June 23, 2022,  3:45pm
The database is defined in the dockerfile:
    depends_on:
      - db
    networks:
      - invoiceninja
    extra_hosts:
      - "in5.localhost:192.168.0.124 " #host and ip
  db:
    image: mysql:5
#    When running on ARM64 use MariaDB instead of MySQL
#    image: mariadb:10.4
#    For auto DB backups comment out image and use the build block below
#    build:
#      context: ./config/mysql
    ports:
      - "3305:3306"
    restart: always
    env_file: env
              Oh, thanks. I usually just install using portainer, hance not familiar with it. Thanks for pointing it out.
              I took a look at docker-compose, but I am not familiar with it.  Is it possible to install using Portainer?  Any instructions anywhere?
                    June 24, 2022,  8:39am
                  5
              Maybe this video will help?
                8 votes and 1 comment so far on Reddit
              I did watch that first.  He is using a separate maria DB container, which isn’t the case here, correct?  It shares his nextcloud maria db with Invoice Ninja.
              Not familiar on how to have another db setup.  So are you saying I will need to install a maria db container?
                    June 24, 2022,  9:09am
                  9
              @david  can you please advise?
                david
                    June 24, 2022,  9:52am
                  10
              @jang430
This thread here may help with configuring portainer
        opened 12:00AM - 29 May 21 UTC
          closed 09:20PM - 26 Jun 21 UTC
    Target :
 Run multiple IN version with different database, public/storage dire… ctory on different subdomain/domain behind caddy (auto ssl).
requirement
Mysql/MariaDB
Caddy
external ip of host server for example 2.2.2.2
multiple Nginx are used to keep public directory of each IN different.
these configuration is for docker swarm mode so might need little changes for normal docker mode.
**invoice.domain.tld**: for production use always online and only upgrade Friday after backup.
version: '3.3'
services:
  invoiceninja:
    image: invoiceninja/invoiceninja:5.1.65
    extra_hosts:
     - invoice.domain.tld:2.2.2.2
    environment:
      APP_DEBUG: 'false'
      APP_KEY: base64:key here
      APP_URL: https://invoice.domain.tld
      DB_DATABASE1: inninja
      DB_HOST1: MariaDB_Host
      DB_PASSWORD1: password
      DB_PORT1: '3306'
      DB_TYPE: MariaDB
      DB_USERNAME1: invoiceninja
      IS_DOCKER: 'true'
      MAIL_MAILER: log
      MULTI_DB_ENABLED: 'false'
      PHANTOMJS_PDF_GENERATION: 'false'
      TRUSTED_PROXIES: "10.0.0.0/8,172.16.0.0/12,192.168.0.0/16"
    volumes:
     - /gfdisk/gv1/invoiceninja/public:/var/www/app/public
     - /gfdisk/gv1/invoiceninja/storage:/var/www/app/storage
     - /gfdisk/gv1/invoiceninja/hosts:/etc/hosts
    networks:
     - invoiceninja
     - mydbnet
    logging:
      driver: json-file
    deploy:
      update_config:
        delay: 600s
  web:
    image: nginx:latest
    extra_hosts:
    volumes:
     - /gfdisk/gv1/invoiceninja/in-vhost.conf:/etc/nginx/conf.d/in-vhost.conf:ro
     - /gfdisk/gv1/invoiceninja/public:/var/www/app/public:ro
     - /gfdisk/gv1/invoiceninja/hosts:/etc/hosts:ro
    networks:
     - caddy_caddy
     - invoiceninja
    logging:
      driver: json-file
    deploy:
      labels:
        caddy: invoice.domain.tld
        caddy.2_reverse_proxy: '{{upstreams 80}}'
        caddy.3_encode: zstd gzip
networks:
  caddy_caddy:
    external: true
  invoiceninja:
    driver: overlay
  mydbnet:
    external: true
**in-vhost.conf**
most important configuration here is root directory and invoice ninja service name.
in case IN container restart it gets new ip every time nginx need to get new ip but it crash. using set/variable will prevent nginx crash.
server {
    listen 80 default_server;
    server_name _;
    client_max_body_size 100M;
    root /var/www/app/public/;
    index index.php;
    location / {
    location = /robots.txt  { access_log off; log_not_found off; }
    location ~ \.php$ {
        resolver 127.0.0.11 ipv6=off;
        set $service invoiceninja_invoiceninja;   #<<<<<<
        fastcgi_pass $service:9000;
        fastcgi_index index.php;
        include fastcgi_params;
        fastcgi_intercept_errors off;
        fastcgi_buffer_size 16k;
        fastcgi_buffers 4 16k;
**hosts**
domain and external ip.
`2.2.2.2 invoice.domain.tld`
**Caddy Config**
need to add nginx service ip or name.
  invoice.domain.tld {
  	reverse_proxy invoiceninja_nginx
  	encode zstd gzip
  	log {
  		level debug
**testninja.domain.tld**:  for testing new version and to allow employees play with so they don't clutter production db with fake client and invoices. most important recurring invoices playground they can fill db with 1000's invoices for no reason.
### Most config are same so posting changes only from above.
version: '3.3'
services:
  testninja:
    image: invoiceninja/invoiceninja:latest
    extra_hosts:
     - testninja.domain.tld:2.2.2.2
    environment:
      APP_URL: https://testninja.domain.tld
      DB_DATABASE1: testninja
      DB_USERNAME1: testninja
    volumes:
     - /gfdisk/gv1/testninja/public:/var/www/app/public
     - /gfdisk/gv1/testninja/storage:/var/www/app/storage
     - /gfdisk/gv1/testninja/hosts:/etc/hosts
    networks:
     - testninja
     - mydbnet
  web:
    image: nginx:latest
    extra_hosts:
    volumes:
     - /gfdisk/gv1/testninja/in-vhost.conf:/etc/nginx/conf.d/in-vhost.conf:ro
     - /gfdisk/gv1/testninja/public:/var/www/app/public:ro
     - /gfdisk/gv1/testninja/hosts:/etc/hosts:ro
    networks:
     - caddy_caddy
     - testninja
    logging:
      driver: json-file
    deploy:
      labels:
        caddy: testninja.domain.tld
networks:
  caddy_caddy:
    external: true
  testninja:
    driver: overlay
  mydbnet:
    external: true
**in-vhost.conf**
        set $service testninja_testninja;   #<<<<<<
**hosts**
`2.2.2.2 testninja.domain.tld`
**Caddy Config**
  testninja.domain.tld {
  	reverse_proxy testninja_nginx
that's it now you can have two separate parallel IN on different subdomain.
### little more about my setup
I have docker swarm with 3 vps and for persistent storage using glusterfs. managing docker cluster with portainer and swarmpit (very useful to get logs from all replicated services across cluster) .
I have custom caddy working with consul.
https://github.com/lucaslorentz/caddy-docker-proxy
https://github.com/pteich/caddy-tlsconsul
caddy-docker-proxy helps in auto creating caddy config and updating ip for nginx service. their is some learning time but it save way more than you ever imagine.
caddy-tlsconsul save all tls certificate to consul so they can be accessed by every caddy server across cluster.
this is my first working caddy docker compose in order to use please create your caddy docker image.
version: '3.3'
services:
  consul:
    image: consul:latest
    command:
     - agent
     - -server
     - -ui
     - -bootstrap-expect=1
    environment:
      CONSUL_BIND_INTERFACE: eth0
      CONSUL_CLIENT_INTERFACE: eth0
      CONSUL_LOCAL_CONFIG: '{"datacenter":"east_tor_do","server":true}'
    volumes:
     - /gfdisk/gv1/CaddyConsul:/consul/data
    networks:
     - consul
    logging:
      driver: json-file
    deploy:
      placement:
        constraints:
         - node.role == manager
  consul_relay:
    image: alpine/socat:latest
    command:
     - TCP-LISTEN:8500,fork,reuseaddr
     - tcp-connect:consul:8500
    ports:
     - 8500:8500
    networks:
     - consul
    logging:
      driver: json-file
    deploy:
      placement:
        constraints:
  controller:
    image: registry.gitlab.com/---------------------/caddy:latest
    environment:
      CADDY_CONTROLLER_NETWORK: 10.200.200.0/24
      CADDY_DOCKER_CADDYFILE_PATH: /Caddy/config/Caddyfile
      CADDY_DOCKER_MODE: controller
      CONSUL_HTTP_ADDR: consul:8500
    volumes:
     - /var/run/docker.sock:/var/run/docker.sock
     - /gfdisk/gv1/Caddy:/Caddy
    networks:
     - caddy
     - consul
     - controller
    logging:
      driver: json-file
    deploy:
      placement:
        constraints:
  server:
    image: registry.gitlab.com/--------------------/caddy:v2.4.0-beta.1-v2.0
    environment:
      CADDY_DOCKER_MODE: server
    ports:
     - 80:80
     - 443:443
    volumes:
     - /gfdisk/gv1/Caddy/www:/www
    networks:
     - caddy
     - consul
     - controller
    logging:
      driver: json-file
    deploy:
      mode: global
      labels:
        caddy_controlled_server: ''
      update_config:
        delay: 10s
networks:
  caddy:
    driver: overlay
  consul:
    driver: overlay
  controller:
    driver: overlay
for reference
https://invoiceninja.slack.com/archives/C01N3QKA6JY/p1620675425040300
              Thank you David.  I’ll read up on it.  Thanks @hillel
              How can we upgrade invoiceninja with a new release without lost current volume or data?
                KevoM
                    July 7, 2023, 11:34am
                  13
              Hello, I just recently pull the latest version 5.13 as requested by the app. All the last data I did lastly (invoices, clients, design) are gone. It is now updated with the data from the state when I did the previous update (5.6). All in between are not there anymore… :((
