i’m currently trying to install the self hosted invoice ninja at a shared hoster (called Ionos or 1und1). I Uploaded everything from the .zip file to the webstorage at /invoiceninja.
My domain invoice.domain.de is pointing to /invoiceninja and i can successfully access https://invoice.domain.de/public but i get an 500 error.
At the log it said production.INFO: db fails so i setup a mariadb and editet the .env file. After that i get the error production.INFO: account table not found - well of course because the database is completely empty.
Is there a way to setup invoice ninja in a shared hoster without cpanel oder softacolous?
If not: Did someyone already install invoice ninja in docker in synology? I can’t get it working there as well…
Hi @hillel,
what logs do you exactly mean?
Because its a shared hoster my access is pretty limited. I have a logs folder in the root directory of my webspace, but there are only logs of what got accessed and therefore no errors.
The only thing i can see is the 500 error as well as the two messages mentioned in the laravel.log.
Is the only way to get a clean database with the setup wizard in invoice ninja?
regards,
Jonas
Hi @hillel,
unfortunately this is not possible in the environment from Ionos.
I just got the domains, webspace and databases to configure. Other things like wordpress and nextcloud are running flawlessly.
in IONOS is the installation not possible you have no rights to run the installer… because of the Server Setup on IONOS… i think there are some missing dependencies (i think “proc_open” and “exec” modules are disabled) look at here
