This looks like an issue with the migration. Can you check the dateformat table in the database to see if it populated?
You may need to run
php artisan migrate:fresh --seed
You may need to run
So I was running as docker on UnRAID for v4. Got v5 up, but creator didnāt test email, and said he doesnt use email on his. So I think his is broke. Anyways, trying to get v5 working with Ubunutu.
I already have a Nginx docker setup on UnRAID, am I able to pass from that install to the ninja installs nginx server, or do i need to route it to a separate public IP address?
This will be the 4th or 5th time trying to get it working. Not sure what I am doing wrong.
There is a thread here that may help
Thanks @david ,
I will try that after I try to get it working on Ubuntu if it doesnt work. Since its the recommended way, I rather try get v5 working there. I got it up, looks like I have permission errors as I am getting. really appreciate your help
It is hard to make out the console error, but it looks like a connection refused error?
Hi @david, thanks, yes it is. I am thinking its permission issue or some sort of security setting somewhere (Iām not a Linux guy, so just been googleing around).
There is a problem most likely in the configuration of your vhost for this domain. Your server is refusing all connections.
youāll want to inspect the nginx logs to see why it is not happy.
Thanks. Thats one thing I was thinking about as well. Let me check the logs, I am running apache. if I cant figure it out ill try nginix.
And then once the prerequisites are ready, you need to go to http://your.domain.com/setup for the initial setup wizard (if you just try to access http://your.domain.com without initial setup you will get error 500 and if you turn on debug youāll see itās due to all the tables missing).
iij24
trying to setup/install invoiceninja from github.
strong text
my test url
http://161.35.5.174/invoiceninja/
this gets a default login form.
Iāve seen something of a register/setup form, but I cant figure out what Iāve screwed up.
http://161.35.5.174/invoiceninja/setup
gets the same default page
so, since Iām using Apache/ubuntu, does anyone have any pointers?
thanks
cat /etc/apache2/sites-available/invoiceninja.conf
<VirtualHost *:80>
ServerAdmin [email protected]
ServerName temp22
ServerAlias temp
DocumentRoot /var/www/html/invoiceninja/public
#DocumentRoot /var/www/html/
<Directory /var/www/html/invoiceninja/public>
DirectoryIndex index.html index.php
# test Options -Indexes +FollowSymLinks +MultiViews
#Options -Indexes +FollowSymLinks +MultiViews
Options +FollowSymLinks
AllowOverride All
Require all granted
##Options -Indexes +FollowSymLinks +MultiViews AllowOverride All Require all granted
##Options Indexes FollowSymLinks MultiViews
##Options -Indexes FollowSymlinks
#Options FollowSymlinks
#AllowOverride All
##Order allow,deny
##allow from all
#Require all granted
</Directory>
#Alias "/invoiceninja" "/var/www/html/invoiceninja/public/"
LogLevel debug
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
root@ubuntu-s-1vcpu-2gb-nyc1-01-base-174:/var/www/html/invoiceninja#
cat ninja/.htaccess
#sendportal
<IfModule mod_negotiation.c>
Options -MultiViews -Indexes
</IfModule>
#Options -MultiViews -Indexes
RewriteEngine On
RewriteBase '/invoiceninja/'
# Redirect everything to the 'laravel' subfolder
##RewriteCond %{REQUEST_URI} ^/$
##RewriteRule ^(.*)$ /invoiceninja/$1 [L]
##RewriteRule ^invoiceninja/(.*)$ public/$1 [L]
# Redirect Trailing Slashes If Not A Folder...
RewriteCond %{REQUEST_URI} (.+)/$
RewriteRule ^ %1 [L,R=301]
# Handle front controller (index.php) rewriting
RewriteRule ^ index.php [L]
#sendportal
RewriteRule ā^.envā - [F,L]
RewriteRule ^(.well-known)($|/) - [L]
#sendportal
# Make sure .env files not not browseable if in a sub-directory.
<FilesMatch ā.env$ā>
# Apache 2.2
<IfModule !authz_core_module>
Deny from all
# Apache 2.4+
<IfModule authz_core_module>
Require all denied
</IfModule>
</FilesMatch>
#sendportal
text/html or text/plaincharset parameter set to UTF-8.AddDefaultCharset utf-8
charsetUTF-8.# Force compression for mangled headers.
# https://developer.yahoo.com/blogs/ydn/pushing-beyond-gzipping-25601.html
<IfModule mod_setenvif.c>
<IfModule mod_headers.c>
SetEnvIfNoCase ^(Accept-EncodXng|X-cept-Encoding|X{15}|~{15}|-{15})$ ^((gzip|deflate)\s*,?\s*)+|[X~-]{4,13}$ HAVE_Accept-Encoding
RequestHeader append Accept-Encoding "gzip,deflate" env=HAVE_Accept-Encoding
</IfModule>
</IfModule>
# Map certain file types to the specified encoding type in order to
# make Apache serve them with the appropriate `Content-Encoding` HTTP
# response header (this will NOT make Apache compress them!).
# If the following file types wouldn't be served without the appropriate
# `Content-Enable` HTTP response header, client applications (e.g.:
# browsers) wouldn't know that they first need to uncompress the response,
# and thus, wouldn't be able to understand the content.
# http://httpd.apache.org/docs/current/mod/mod_mime.html#addencoding
<IfModule mod_mime.c>
AddEncoding gzip svgz
</IfModule>
# Compress all output labeled with one of the following media types.
# IMPORTANT: For Apache versions below 2.3.7 you don't need to enable
# `mod_filter` and can remove the `<IfModule mod_filter.c>` & `</IfModule>`
# lines as `AddOutputFilterByType` is still in the core directives.
AddOutputFilterByType DEFLATE "application/atom+xml" \
"application/javascript" \
"application/json" \
"application/ld+json" \
"application/manifest+json" \
"application/rdf+xml" \
"application/rss+xml" \
"application/schema+json" \
"application/vnd.geo+json" \
"application/vnd.ms-fontobject" \
"application/x-font-ttf" \
"application/x-web-app-manifest+json" \
"application/xhtml+xml" \
"application/xml" \
"font/opentype" \
"image/svg+xml" \
"image/x-icon" \
"text/cache-manifest" \
"text/css" \
"text/html" \
"text/javascript" \
"text/plain" \
"text/vtt" \
"text/x-component" \
"text/xml"
</IfModule>
cat public/.htaccess
RewriteEngine On
RewriteBase /invoiceninja
RewriteRule ^(.*)/$ /$1 [L,R=301]
# Handle Front Controller...
# Handle Authorization Header
RewriteCond %{HTTP:Authorization} .
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
#āsnipe
Options -Indexes
<Files āweb.configā>
Order allow,deny
Deny from all
