hi,
did an install of the github app.
now, when firing up the app, i get a login screen, as opposed to a registration form.
so, any pointers on what i’ve screwed up?
thanks
hi,
thanks
Do you see any records in the users table?
yep. 3 which appear to be default.
i also saw something somewhere about a client portal to somehow set
-dont see a client dir though…
Do you recognize the emails in the users table?
Once logged into the app you can access the client portal from a client or invoice.
the emails are from the default github install
everything is default github
is there a separate client app for invoiceninja
i’m simply trying to setup a demo to look around at the ux/ui
i followed the steps to setup/install from the repos
the test url
http://161.35.5.174/invoiceninja
it has a login form…
i dont have any other access… did i screw something up in the install/setup
You can download the desktop app here: OS tools - Free Invoicing Software for Small Businesses | Invoice Ninja
The setup process should set your initial user, you can use the recover password option to set a new password.
why do i need desktop
i thought the webapp was the app
are you saying the webapp is useless
You don’t need it, you asked if there was a client app available
im actually trying to to figure out how to access the webapp from github. i dont see how to register with it
did u look at the url?
how does one sign up/register
In a clean install you can use the /setup route to create the first user.
I haven’t tried accessing your app.
um… 1st ive heard of setup!! any pointers to this. was it in the github install steps and i missed it
I suggest following one of the installation guides
these are what i had used…
however
http://161.35.5.174/invoiceninja/setup
apparently redirects to the index.php – the default form…
You may want to try using an automated installer like Docker or Softaculous
that doesnt help with solving the issue… but thanks…
the test dir is
it appears the issue might be in the apache/.htaccess conf files…
there is a /public/js/setup dir..
my conf files are
iij24
trying to setup/install invoiceninja from github.
my test url
this gets a default login form.
I’ve seen something of a register/setup form, but I cant figure out what I’ve screwed up.
gets the same default page
so, since I’m using Apache/ubuntu, does anyone have any pointers?
thanks
cat /etc/apache2/sites-available/invoiceninja.conf
<VirtualHost *:80>
ServerAdmin [email protected]
ServerName temp22
ServerAlias temp
DocumentRoot /var/www/html/invoiceninja/public
#DocumentRoot /var/www/html/
<Directory /var/www/html/invoiceninja/public>
DirectoryIndex index.html index.php
# test Options -Indexes +FollowSymLinks +MultiViews
#Options -Indexes +FollowSymLinks +MultiViews
Options +FollowSymLinks
AllowOverride All
Require all granted
##Options -Indexes +FollowSymLinks +MultiViews AllowOverride All Require all granted
##Options Indexes FollowSymLinks MultiViews
##Options -Indexes FollowSymlinks
#Options FollowSymlinks
#AllowOverride All
##Order allow,deny
##allow from all
#Require all granted
</Directory>
#Alias "/invoiceninja" "/var/www/html/invoiceninja/public/"
LogLevel debug
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
root@ubuntu-s-1vcpu-2gb-nyc1-01-base-174:/var/www/html/invoiceninja#
cat ninja/.htaccess
#sendportal
<IfModule mod_negotiation.c>
Options -MultiViews -Indexes
</IfModule>
#Options -MultiViews -Indexes
RewriteEngine On
RewriteBase '/invoiceninja/'
# Redirect everything to the 'laravel' subfolder
##RewriteCond %{REQUEST_URI} ^/$
##RewriteRule ^(.*)$ /invoiceninja/$1 [L]
##RewriteRule ^invoiceninja/(.*)$ public/$1 [L]
# Redirect Trailing Slashes If Not A Folder...
RewriteCond %{REQUEST_URI} (.+)/$
RewriteRule ^ %1 [L,R=301]
# Handle front controller (index.php) rewriting
RewriteRule ^ index.php [L]
#sendportal
RewriteRule “^.env” - [F,L]
RewriteRule ^(.well-known)($|/) - [L]
#sendportal
# Make sure .env files not not browseable if in a sub-directory.
<FilesMatch “.env$”>
# Apache 2.2
<IfModule !authz_core_module>
Deny from all
# Apache 2.4+
<IfModule authz_core_module>
Require all denied
</IfModule>
</FilesMatch>
#sendportal
text/html or text/plaincharset parameter set to UTF-8.AddDefaultCharset utf-8
charsetUTF-8.# Force compression for mangled headers.
# https://developer.yahoo.com/blogs/ydn/pushing-beyond-gzipping-25601.html
<IfModule mod_setenvif.c>
<IfModule mod_headers.c>
SetEnvIfNoCase ^(Accept-EncodXng|X-cept-Encoding|X{15}|~{15}|-{15})$ ^((gzip|deflate)\s*,?\s*)+|[X~-]{4,13}$ HAVE_Accept-Encoding
RequestHeader append Accept-Encoding "gzip,deflate" env=HAVE_Accept-Encoding
</IfModule>
</IfModule>
# Map certain file types to the specified encoding type in order to
# make Apache serve them with the appropriate `Content-Encoding` HTTP
# response header (this will NOT make Apache compress them!).
# If the following file types wouldn't be served without the appropriate
# `Content-Enable` HTTP response header, client applications (e.g.:
# browsers) wouldn't know that they first need to uncompress the response,
# and thus, wouldn't be able to understand the content.
# http://httpd.apache.org/docs/current/mod/mod_mime.html#addencoding
<IfModule mod_mime.c>
AddEncoding gzip svgz
</IfModule>
# Compress all output labeled with one of the following media types.
# IMPORTANT: For Apache versions below 2.3.7 you don't need to enable
# `mod_filter` and can remove the `<IfModule mod_filter.c>` & `</IfModule>`
# lines as `AddOutputFilterByType` is still in the core directives.
AddOutputFilterByType DEFLATE "application/atom+xml" \
"application/javascript" \
"application/json" \
"application/ld+json" \
"application/manifest+json" \
"application/rdf+xml" \
"application/rss+xml" \
"application/schema+json" \
"application/vnd.geo+json" \
"application/vnd.ms-fontobject" \
"application/x-font-ttf" \
"application/x-web-app-manifest+json" \
"application/xhtml+xml" \
"application/xml" \
"font/opentype" \
"image/svg+xml" \
"image/x-icon" \
"text/cache-manifest" \
"text/css" \
"text/html" \
"text/javascript" \
"text/plain" \
"text/vtt" \
"text/x-component" \
"text/xml"
</IfModule>
cat public/.htaccess
RewriteEngine On
RewriteBase /invoiceninja
RewriteRule ^(.*)/$ /$1 [L,R=301]
# Handle Front Controller...
# Handle Authorization Header
RewriteCond %{HTTP:Authorization} .
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
#–snipe
Options -Indexes
<Files “web.config”>
Order allow,deny
Deny from all
