I find the entire IN community very interesting, and currently the entire community exists within the bubble of Discouse. What I was wondering if there is any intrest/traction for a Discord server for InvoiceNinja. Either owned by the devs, or the community.
In the same way, if anyone sees the use of a Discord bot that allows you to generate invoices cross application. (From Discord → IN).
Hi @david!
You have sent the direct of a discord channel. That doesn’t work. You’ll have to do the following to invite other people:
Click on the man with the + next to any channel name.
On the bottom of the popup, you’ll see that the invite will expire in 7 days. That might be a tad bit to short
So what you do, is click on “Edit invite link”.
And click on “Generate a New Link”. Once you’ve done that, it will show you an invite link with a “copy” button. Click on that and it’ll copy the invite link to your clipboard.
That link is eventually shared with whoever you want to share it with
