Ok, got it, thank you for pointing me to the solution. Invoice settings seems are now under “company details → defaults”
This raise new question related to missing imported fileds from V4. Also fields like “deafult payment terms”, “default payments temrs” are not imported from V4
Hi guys, maybe it’s just me, but I can’t still migrate the settings above. Everything is working fine on both installations (v5.1.62-C47 and v4.5.39) except for this.
A workaround could be to not overwrite the settings above each time I launch the migration, so i can set up on V5 the right defaults and other settings and just import the data. Just thinking.
Anyway, could you please just verify if is working fine on your side in order to understand if this issue on migration it’s just on my environment?
Nothing on logs, just normal records about successfull things, no errors.
