Inconsistancy between React and Flutter
When will all the inconsistancies between the different apps be removed? Below is just one example of many I’ve noticed.
React Web
Flutter Desktop
HI,
What exactly are you referring to in the screenshots, that the Flutter app uses a toggle to enable/disable the feature rather than a “1 second” option?
The select has different values. Flutter misses 1 Second (Disabled)
In the Flutter app there is a toggle to enable/disable rounding which has the same effect.
this is quite confusing…
If you’d like to see a change made in either of the apps feel free to create an issue on GitHub.
